  2. Logic Design
  3. HELP WITH Integral nonlinearity (INL) and differential nonlinearity...
  • Subscribers 64
  • Views 10799
HELP WITH Integral nonlinearity (INL) and differential nonlinearity (DNL) of data converters
Saori
Saori over 3 years ago
Hi, I'm developing an A/D converter in the LTspice program. However, the circuit presented problems and I only have the transfer curve.
I need to do a performance tests, find the INL and DNL error, how to do it in matlab?
Does anyone know how to assemble the function below from the vectors I have for the curve?
s = inldnl(analog,digital,range,type)
s = inldnl(___,Name,Value)
    ShawnLogan over 3 years ago +1
    Dear Saori, Saori said: Hi, I'm developing an A/D converter in the LTspice program. However, the circuit presented problems and I only have the transfer curve. I need to do a performance tests, find…
    Dear Saori,
    Are you using spectre or LTspice? If the latter, I am not sure why you are asking your question in the Cadence Forum, or perhaps you are loading the LTspice data into ViVA? MATLAB issues can be discussed in the MATLAB forums, but your question seems to be a rather obvious as there exists a MATLAB function inldnl().
    In any case, there are multiple means to analyze the DNL and INL of a data converter output using Cadence tools. I have used both ocean scripts as well the ViVA dnl() and inl() functions to determine DNL and INL performance. The two ViVA functions are described in its On-line support reference manual at URL:
    support.cadence.com/.../techpubDocViewerPage
    Shawn
