  2. Mixed-Signal Design
  3. Export LEF via problem
  • Subscribers 63
  • Views 15485
Gangadhar Redd
Gangadhar Redd over 13 years ago
 Hi ,
While I trying to export .lef file from Cadence virtuoso 6.1.5 version , I got the following error
"ERROR: (OALEFDEF-50138): VIA Via56_stack_west: Failed to open master view - Open of gpdk180/Via56_stack_west/symbolic failed - cellView for the design was not found - Ensure that the via is correctly defined in the technology database."
Can anybody please solve this problem ?
Thanks & Regards,
Gangadhar.R
  • AndreasLenz
    AndreasLenz over 13 years ago
    Hello Gangadhar,
    Did you manage to export a LEF from Virtuoso meanwhile? Does the view name exist (please check with the library manager) ?
    The LEF export uses the foundry section of the technology library - is the via defined ? You could use CIW - Technology Manager - Dump to write out an ASCII text file and search for the via.
    Andreas
