  2. Mixed-Signal Design
  3. Simulating and retrieving MOS currents
  • Subscribers 65
  • Views 14920
Mike59
Mike59 over 13 years ago
Briefly, what I would like to do using Spectre, is a DC sweep of a MOS transistor. This sweep will include the node voltages, plus the gate length and width. Now, I've figured out how to do this using a "sweep paramset" command, like this:
mysweep sweep paramset=allinone {
  mydc dc
where the parameter set named "allinone" gets included from another file.
However, I would also like to be able to read the results from one text file, but this command produces a separate file in the raw directory for every dc point. Is there any way to avoid creating the raw directory in the first place, and simply have Spectre output or even print to the console the dc currents of all the dc points, one after another? I have tried to use a print command, but as it's not allowed inside the sweep, it only prints out the results of the last dc point. Writing all the separate dc files also seems to slow down the simulation quite a bit.
BR, Mikael
  • Isto
    Isto over 13 years ago
    Hi Mikael,
    As we discussed offline, you should use spectremdl. MDL allows to do complex measurements and run them in batch. It also allows automatic deletion of the binary results data  after the simulation is finished leaving only the exported text results.
    BR,
    Isto
