  2. Mixed-Signal Design
  3. Step a bus signal from ADE-XL design variable
  • Subscribers 64
  • Views 16601
daasboe
daasboe over 13 years ago
Is there a way for me to use design variables in ADE-XL to step through all possible values in a bus, say a_signal<3:0>, and run a DC simulation for each step?
Daniel
    Andrew Beckett over 13 years ago +1
    Daniel, One way would be to use the bussetp component as outlined in my solution on Cadence Online Support . Kind Regards, Andrew.
    Daniel,
    One way would be to use the bussetp component as outlined in my solution on Cadence Online Support.
    Kind Regards,
  • daasboe
    Works like a charm. Thanks!
