  2. Mixed-Signal Design
  3. How often does AMS flush outputs by default during a simulation...
  • Subscribers 64
  • Views 15580
How often does AMS flush outputs by default during a simulation?
royK
royK over 13 years ago
Iam running a long transient simulation using AMS designer. I would like to flush the simulation results periodically in order to view results as the simulation progresses.
Do we have flushpoints and flushtime(s) options available in AMS just as we have in spectre? Please suggest me.I am using INCSIV 12.2 version.
Thank you in Advance.
    As far as I know, flushtime/flushpoints do not work with SST2 format output (even in spectre), so I'm not sure of the answer of this (without doing some deeper digging, which I don't really have the time to do now). If this is important to you, please create a case with customer support.
    Kind Regards,
