  2. Mixed-Signal Design
  3. NC-Verilog Integration netlister explicitly option
  • Subscribers 63
  • Views 16833
Provence
Provence over 12 years ago
Hi all,
Through Virtuoso Verilog Environment for NC-Verilog Integration ,I initialize a analog design ,then setup netlist explicitly option to ture.
I hope to generate  that the netlister used the pin name method as following .
The result is out of my expectation. some part of netlist remain the pin order method. below is example.
 PIN ORDER:
transmitter_driver_TX I2 ( .tx_control(net0159), .en_lpcd(en_LP), .U6(net044), .U5(net045), .U4(net046), .U3(net047),      .U2(net048), .U1(net049), .D4(net050), .D3(net051), .D2(net0130), .D1(net052), .TX(TX2));
PIN NAME :
 transmitter_top I10 ( pad_Tx1, pad_Tx2, AS_sel, CWGsPReg[0], CWGsPReg[1], CWGsPReg[2], CWGsPReg[3], CWGsPReg[4],
     CWGsPReg[5], data, force100ask, GsNReg[0], GsNReg[1], GsNReg[2], GsNReg[3], GsNReg[4], GsNReg[5], GsNReg[6], GsNReg[7],
     ModGsPReg[0], ModGsPReg[1], ModGsPReg[2], ModGsPReg[3], ModGsPReg[4], ModGsPReg[5], Tx1rfen, Tx2cw, Tx2rfen,
     en_trans_lp, enb_transmitt, invTx1rf, invTx2rf, net272);
Now, Can anyone tell why ? What happen , transmitter_top I10 ?
  • Provence
    Hi all,
     PIN ORDER:
    PIN NAME :
    For some reason your post was locked (I assume you locked it...) - luckily as moderator I can unlock it, but locking a post means that nobody can reply!
    The NC Verilog netlister will report in the CIW any time it can't meet explicit netlisting, and why. Usually it's because of split busses, which may be the case here - sometimes the syntax doesn't really allow passing by name if you have split busses. But the CIW log should tell you the reason - did you look at that?
    Kind Regards,
  • Provence
     as  you say , I find some warning messages that specify CEll has split buses across module ports and module will printted out with ranges.
    Thanks for your help.
