  2. Mixed-Signal Design
  3. Transient flicker noise simulation
  • Subscribers 64
  • Views 17490
Masoud ensaf
Masoud ensaf over 13 years ago
 I want to run a transient simulation in Spectre with flicker noise ON. I set both Fmin and Fmax values. I am interested in the noise in the first 100ns of the simulation but I noticed that I have to set the simulation stop time to 1/Fmin (which is a very long simulation time), in order to get the correct answer. The noise in the first 100ns is less if I set an stop time less than 1/Fmin. It seems that Spectre turns on the noise sources based on the stop time. I want to run my simulation only for the first 100ns that I am interested in. Does anyone know how I can get around this problem?
Masoud
    Masoud,
    If you're only simulating for 100ns, that's only 1 cycle of 10MHz. So you're not really going to get any significant effect of any noise below 10MHz - which is presumably where the flicker noise dominates.
    That's why you really want the simulation stop time to be 1/Fmin - you have to be simulating for long enough to be able to observe the noise at a particular frequency.
    So by all means only run the simulation for 100ns, but you won't really get any flicker noise... then again, maybe your circuit is not going to be sensitive to flicker noise?
    What kind of circuit is it that you're simulating?
  • Masoud ensaf
    Thank you for your reply,
    Actually, I am only interested in the variance of the Flicker noise and I wanted to find out if I can find the variance by running multiple short time simulations with multiple noise seeds instead of one long simulation.But it seems that it works only if I set the stop time to 1/Fmin. My test setup is one simple opamp. It seems that spectre turns on the noise sources based on the stop time. If I set the stop time to 1/Fmin, is there a way I can stop the simulation after 100ns?
    Masoud
