  2. Mixed-Signal Design
  3. How to setup Cadence ADE to simulate basic digital blocks...
  • Replies 8
  • Subscribers 65
  • Views 19764
How to setup Cadence ADE to simulate basic digital blocks successfully
bhl3302
bhl3302 over 13 years ago
Hi, I am using Virtuoso IC6.1.5 with IBM BiCMOS8HP technology. It runs well in ADE for analog design. But when I imported digital library of this technology,draw a basic circuit schematic with AND block, and include .scs file and verilog file for this AND block, the simulation was not successful. The error message showed here is
 *INFO* (icLic-25) License Analog_Design_Environment_XL ("95210") was used to run ADE L.
Loading analog.cxt
Loading asimenv.cxt
Loading spectrei.cxt
Loading relXpert.cxt
Loading par.cxt
Loading socket.cxt
Loading alvs.cxt
t
sevLoadState('sevSession1)
hiiSetCurrentForm('sevLoadForm1)
t
hiFormDone(sevLoadForm1)
Loading devCheck.cxt
t
t
sevNetlistAndRun('sevSession1)
Delete psf data in /ece/grad/yhuang85/simulation/4_130818/spectre/schematic/psf.
generate netlist...
Loading spectreinl.cxt
Loading seCore.cxt
Begin Incremental Netlisting Aug 18 21:50:35 2013
WARNING (OSSHNL-145): Incremental netlisting is not possible since the netlist in this run directory
was generated using a previous IHNL version which is incompatible with the
current IHNL version. Therefore re-netlisting the entire design using the
ERROR (OSSHNL-116): Unable to descend into any of the views defined in the view list, 'spectre cmos_sch cmos.sch schematic veriloga', for the
instance 'AND2_I0' in cell '4_130818'. Either add one of these views to the library 'digital_library',
cell 'AND2_I' or modify the view list to contain an existing view.
End netlisting Aug 18 21:50:35 2013
ERROR (OSSHNL-514): Netlisting failed due to errors reported before. Netlist may be corrupt or may not be produced at all. Fix reported errors and netlist again.
      ...unsuccessful.
Could anyone teach me if there is any mistake I make in ADE setup in order to run this circuit? Thank you very much!
    If your digital library only has verilog descriptions, you won't be able to simulate it with spectre; spectre is an analog circuit simulator and like other SPICE-like simulators, doesn't handle logic level verilog descriptions.
    For that you'd need to use "AMS Designer" (ams as the simulator in ADE). I suggest you start with the AMS Designer Tutorial in the documentation.
  • marten
    marten over 12 years ago
    Hi there,
    what files are needed to run Spectre on digitial elements (like NAND, NOR,.. ) ? We have a PDK installed but I am not sure if the necessary files for analog sim of the digital elements are included. Could you give me a kick in the right direction ?
    Best regards,
    Marten
    Does the library of digital elements have schematics?
  • marten
     yes there are schematics available for nearly every element. Also I found a bunch of *.scs-files within the PDK.
     Marten
    You're probably good to go then. You might want to check with the provider though - they ought to document what they support...
  • marten
     Thanks for the quick reply!
    Maybe you can give a short overview how to load these files into ADE ?
    Marten
    If you have schematics, then I wouldn't have thought you need the .scs files if they are describing the same cells.
    As I said, you should ask the provider precisely what you are supposed to do as this can vary from supplier to supplier. I can't really guess without seeing what information you have.
  • marten
     Okay I will do so.
    Thanks for your help!
    Marten
