  2. Mixed-Signal Design
  3. issue in vhdl-ams compilation
  • Replies 8
  • Subscribers 65
  • Views 21304
sebgimi
sebgimi over 12 years ago
I'm trying to write a code for a comparator in vhdl-ams. I use incisiv (13.10.013) and when I compile the code (just the entity) an error is occuring:
This is my code:
library ieee;
use ieee.electrical_systems.all;
use ieee.std_logic_1164.all;
use ieee.math_real.all;
entity comparator is
 generic (level : real := 2.5; -- threshold
   vcc   : real := 5.0;
   gnd   : real := 0.0);
 port(--terminal e: electrical;  -- analogic in
            signal   s: out std_logic); -- digital out
end comparator;
When I write exactly what is below, the following error is occuring:
ncvhdl -work st_lib -message ../sources/comparateur_ent.vhdl
ncvhdl: 12.20-p001: (c) Copyright 1995-2012 Cadence Design Systems, Inc.
../sources/comparateur_ent.vhdl:
ncvhdl_p: *E,SELLIB (../sources/comparateur_ent.vhdl,2|8): unit (ELECTRICAL_SYSTEMS) not found in library (IEEE).
        errors: 1, warnings: 0
It look like that the library electrical_systems is not recognized by the compiler.
 Someone can help please?
    If in your cds.lib you have something like this:
     INCLUDE $IUSHOME/tools/inca/files/cds.lib
    which will give you access to the IEEE (ieee) library. However, for AMS use you need to instead have:
     INCLUDE $IUSHOME/tools/inca/files/IEEE_vhdlams/cds.lib
    If you compile your example with this in your cds.lib, it will compile fine.
  • sebgimi
    Thanks a lot! That's work now, but when I remove comment on the following line: " terminal e : electrical; " this error appear:
    ncvhdl: 13.10-s013: (c) Copyright 1995-2013 Cadence Design Systems, Inc.
            port(terminal e: electrical;  -- entree analogique
    ncvhdl_p: *E,MISCOL (../sources/comparateur_ent.vhdl,12|15): expecting a colon (':') 87[4.3.3] 93[4.3.2].
    Is this ok if the word "terminal" is not in color like others key word in ams? Do I use the right library for vhdl-ams?
    I didn't notice this earlier, but you need to pass -ams on the ncvhdl command line:
     ncvhdl -work st_lib -ams -message ../sources/comparateur_ent.vhdl
    That will fix the problem. You need this if you are compiling VHDL-AMS code.
  • sebgimi
     Everything is ok now, thank you very much!
    Sebastien.
  • srana01
    srana01 over 9 years ago
    Has the cds.lib location for ams changed in the most recent version of Cadence (6.1.6 64b)? When I use the above statement in my cds.lib file I get the following error on compilation:
    ncvhdl: *W,DLCPTH (./cds.lib,28): cds.lib No such file '/Incisive/tools/inca/files/cds.lib' (cds.lib command ignored).
    TOOL: ncvhdl(64) 14.10-s004: Started on Apr 27, 2017 at 11:02:41 BST
    No, this has not changed. Are you sure that your INCISIVE installation is at /Incisive? Perhaps $IUSHOME is not set properly.
    This is nothing to do with the IC version you're using (IC6.1.6) - it's related to whatever you have set $IUSHOME to in your environment.
  • srana01
    Thanks Andrew.
    I have found two locations which seem relevant:
    usr/local/cadence/current2016-17/INCISIVE_15.20.010/tools/inca/files/IEEE_vhdlams/cds.lib
    and
    usr/local/cadence/current/INCISIV141/tools.lnx86/inca/files/IEEE_vhdlams/cds.lib
    do you think either of these might be the correct cds.lib file?
  • srana01
    Sorry, the two locations are as follows:
    usr/local/cadence/2016-17/INCISIVE_15.20.010/tools/inca/files/IEEE_vhdlams/cds.lib
    and
