  2. Mixed-Signal Design
  3. verilog simulation
  • Subscribers 64
  • Views 15804
verilog simulation
sebgimi
sebgimi over 12 years ago
 I am trying to write and simulate my first code in verilog, but I can't simulate it. When I run simulation the chronograms stay empty .
My code is a simple 3-in AND gate:
 module and3 (e1, e2, e3, s);
 input e1;
 input e2;
 input e3;
 output s;
 assign s = e1 & e2 & e3;
endmodule
And below, the testbench I use:
`timescale 1ns / 10ps
module and3_tb;
     reg e1_t, e2_t, e3_t;
     wire s_t;
     and3 and3( .e1(e1_t), .e2(e2_t), .e3(e3_t), .s(s_t) );
     initial
     begin
          $monitor(e1_t, e2_t, e3_t, s_t);
          e1_t = 1'b0;
          e2_t = 1'b0;
          e3_t = 1'b0;
          #5
          e1_t = 1'b0;
          e2_t = 1'b0;
          e3_t = 1'b1;
          #5
          e1_t = 1'b0;
          e2_t = 1'b1;
          e3_t = 1'b0;
          #5
          e1_t = 1'b0;
          e2_t = 1'b1;
          e3_t = 1'b1;
          #5
          e1_t = 1'b1;
          e2_t = 1'b0;
          e3_t = 1'b0;
          #5
          e1_t = 1'b1;
          e2_t = 1'b0;
          e3_t = 1'b1;
          #5
          e1_t = 1'b1;
          e2_t = 1'b1;
          e3_t = 1'b0;
          #5
          e1_t = 1'b1;
          e2_t = 1'b1;
          e3_t = 1'b1;
     end
endmodule
I use ncvhdl/ncsim suit with incisiv, below its how I write the commands:
 ncvlog -work work -message \
../modules/and3.vlog \
../modules/and3_tb.vlog
ncelab -cdslib cds.lib -hdlvar hdl.var -messages -access +r+w+c -update -timescale '1ns/10ps' -logfile ncelab.log work.and3
 ncsim -gui -messages -nocopyright -log ncsim.log work.and3
So when I run ncsim, at the moment I choose the input/output of the module (e1,e2,e3,s here) the initials values are 'x', but when I compare with a simulation in vhdl these values are 'U'. So when this part is finish I run the simulation and nothing happens...
Can you help me please?
    This is because you're elaborating and simulating the wrong thing. You're elaborating and simulating work.and3 whereas it should be work.and3_tb - if you do that, then it works. There's no stimulus otherwise!
  • sebgimi
    I'm such a fool!! It was so simple and I didn't see that...
    Thank you for your help!
    Sebastien
