  2. Mixed-Signal Design
  3. VerilogA in AMS simulation: string parameter is not properly...
  • Subscribers 64
  • Views 17057
VerilogA in AMS simulation: string parameter is not properly recognized
jsaenznoval
jsaenznoval over 12 years ago
I'm running  a AMS Simulation using  Cellview-based netlister and Spectre Solver. My simulation compiles fine when I configure all my cells to be only VerilogA. However, when I set the simulator to be AMS, Cellview-based netlister gives me the following error:
file: /home/jorge/smdh/zr16_lp/analog/designers/jorge/top_simulation/smdh_ips/P2S/veriloga/veriloga.va
    parameter string test_vector = "test_vector_adc1_en.dat" exclude {""};   // Test vector follows the pattern in the input file: Index   Logical value [0,1]
ncvlog: *E,EXPEQL (/home/jorge/smdh/zr16_lp/analog/designers/jorge/top_simulation/smdh_ips/P2S/veriloga/veriloga.va,42|28): expecting an equal sign ('=') [3.10(IEEE)].
    module worklib.P2S:va
The definition of string parameters works  fine in VerilogA. I don't know what is different from VerilogAMS and VerilogA on this case.
I really don't know how I could fix it.
Thanks!
    Two solutions - either remove the "string" keyword (there's a Cadence Change Request to get this fixed in AMS), or use the OSS netlister (which will simulate the veriloga module as veriloga in the spectre solver rather than simulating it as VerilogAMS).
  • jsaenznoval
     Thanks for your helpful reply,
    Regards
    Jorge Johanny Sáenz N.
