  2. Mixed-Signal Design
  3. ERROR (VACOMP-1008): Cannot compile ahdlcmi module libr...
  • Subscribers 64
  • Views 16238
ERROR (VACOMP-1008): Cannot compile ahdlcmi module library
jsaenznoval
jsaenznoval over 12 years ago
 I'm trying to simulate a circuit using ams simulator  with Verilog and VerilogA cells but unexpectly iRun log returns me the following error:
Compiling ahdlcmi module library.
Error found by aps during AHDL read-in.
    Cannot compile ahdlcmi module library. Check the log file
        amsControlAPS.ahdlSimDB/3980_sm2101350h_zr16_sar_sar_adc10b_veriloga_veriloga.va.sar_dac10b_cap_v1_top.ahdlcmi/Linux2.6.32-358.6.2.el6.x86_64-64+gcc/../ahdlcmi.out
        for details. If the compiler ran out of memory, use 'setenv
        CDS_CMI_COMPLEVEL 0', and try again. If the reason for the failure was
        a syntax error, contact your Cadence Customer Support representative
        with the netlist, log files, behavioral model files, and any other
        information that can help identify the problem.
VerilogA view for sar_dac10b_cap_v1_top compiles fine using spectre and/or APS with all analog blocks
I attached the log files.
  • ahdlcmi.txt
    That looks like a bug in the VerilogA compilation, but since you are using an ancient release (there have been numerous INCISIV releases since IUS82), you should start by trying this in a more recent release (eg INCISIV132) and if it still occurs (much less likely, but it might), then you should contact customer support.
  • jsaenznoval
    The compilation process was successfully finished after I updated my INCISIV version.
     Thanks Andrew
