  2. Mixed-Signal Design
  3. AMS Simulation fails with error 127?
  • Subscribers 64
  • Views 17222
Kabal
Kabal over 12 years ago
I have set up the basic mixed-signal testbench. Just imported a verilog file with clock generator, created a symbol for it and added it in a simple testbench where it is driving schematics built inverter cell.
I arranged the ADE GXL simulator with ams option. I Set up the connect modules for 1.8V. Everything seems fine.
When I run the simulation it fails with this error:
Elaborating the design hierarchy:
ERROR: terminated with error code 127
ncelab: *F,SPRSER: Spice/Spectre file parsing failed.
I have no idea what on earth does that mean? What is error 127?
This error can be seen in ncelab.log and simulation.log files, everything else in those log files does not have error, same goes for netlister.log and ncvlog.log files, no errors.
What that could be and how to fix it?
  • Kabal
    Oh well... I had to run runSimulation file from netlist directory directly in order to figure out that it didn't run because I did not have a library called libreadline.so.5
    "CAD on Linux in 2014"...
