  2. Mixed-Signal Design
  3. Verilog-A module instantiating
  • Subscribers 66
  • Views 26702
Jacob Bao
Jacob Bao over 12 years ago
Dear all,
I'm modifying my original Verilog-A module M1 and it has Verilog-A and schematic views with corresponding input/outout ports.
Now I'm trying to add an another module M2 into M1.
So I add the M2's Verilog-A code above M1's which is like below.
`include "disciplines.vams"
module M2(a,b);
endmodule
module M1(aa,bb,...);
M2 G1(a,b);
endmodule
Error messages:
Error found by spectre during AHDL read-in.
ERROR (VACOMP-2259): "M2<<--? G1(a,b);"
"/home/..../variloga.va", line 97: syntax error
I did my best to check the systax rules.
What's wrong with this?
    I just used this and it worked fine:
    module hierLower(a,b,f);
    inout a,b,f;
    electrical a,b,f;
    parameter real r=1k;
    analog begin
    //  if ($port_connected(f)) begin
    //    $strobe("f is connected\n");
    //  end
      V(a,b)<+I(a,b)*r;
    end
    endmodule
    module hierUpper(c,d);
    input c,d;
    electrical c,d;
    //hierLower R1(.a(c),.b(e),.f(n));
    hierLower R1(.a(c),.b(e));
    hierLower R2(.a(e),.b(d));
    endmodule
    So my guess is that the syntax error is probably in something before the line it mentions, in the part you omitted from your post. Maybe a missing semi-colon?
  • mehdina94rm
    mehdina94rm over 9 years ago
    I have got exactly the same error.
    Error (VACOMP-2259): " parameter gain =<<--?  1;"
    here is my code:
    Module CCVS(pout,nout,pin,nin);parameter gain = 1;
    analog V(pout,nout) <+ gain * I(pin,nin)
    endmodule
    It is so simple but I do not know where is the issue.
    Well, there are several things wrong with your code, but I don't get the error you show - I'm assuming you haven't got precisely what you posted as your code. For example, at least:
    1. The "Module" should be "module" (the language is case sensitive).
    2. You are using the V() and I() access functions, but don't declare any disciplines (`include "disciplines.vams")
    3. You didn't specify the discipline of the pout,nout,pin,nin signals
    4. You're missing a semi-colon on the end of the contribution statement.
    All in all, it should be this:
    module CCVS(pout,nout,pin,nin);
    electrical pout,nout,pin,nin;
    parameter gain = 1;
    analog V(pout,nout) <+ gain * I(pin,nin);
    endmodule
  • manu22
    manu22 over 5 years ago in reply to Andrew Beckett
    Sir I have a similar error,
    ERROR (VACOMP-2259): ""sign_multply="0<<--? ;"
    "/home/buet/cds_work/memristo_vteam/vteam/schematic/veriloga.va", line
    171: syntax error.
    ERROR (VACOMP-2259): ""sign_multply="1<<--? ;"
    173: syntax error.
    ERROR (VACOMP-2212): "sign_multply=<<--? 0;"
    177: Encountered undeclared identifier: sign_multply. Declare the
    identifier before using it.
    "w=dwdt*dt*(1-pow(2*w/D-1,2*p_coeff))+w_last+sign_multply*<<--?
    p_window_noise;"
    183: Encountered undeclared identifier: sign_multply. Declare the
    ERROR (VACOMP-1552):
    183: Encountered left operand of type *undef* for operator `*'. Specify
    a real or an integer type operand instead.
    ERROR (VACOMP-2259): "if (stp(-I(p,n))<<--? == 1) begin"
    190: Encountered an undefined function stp. Check the spelling of the
    function or define the function before using it..
    sign_multply=0;
    if(w==0) begin
    sign_multply=1;
    end
    end
    if (sign(I(p,n))==-1) begin
    sign_multply=0;
    if(w==D) begin
    sign_multiply=-1;
    end
    end
    w=dwdt*dt*(1-pow(2*w/D-1,2*p_coeff))+w_last+sign_multply*p_window_noise;
    end // Jogelkar window
    // Biolek window
    if (window_type==2) begin
    if (stp(-I(p,n)) == 1) begin
    stp_multply=1;
    end
    if (stp(-I(p,n)) == 0) begin
    stp_multply=0;
    end
    Andrew Beckett over 5 years ago in reply to manu22
    I struggle to see what on earth this has to do with this thread - other than both being Verilog-A related.
    The errors are completely different and the forum guidelines ask you not to append on the end of old threads (and provide the versions you're using, and give enough information to fully describe the issue, none of which you've done).
    However, in this case the errors are pretty clear - it's saying you've not declared:
    1. sign_multply
    2. The function stp()
    Since you've not provided the entire model but just parts of it, debugging the rest is rather difficult - but presumably you're going to have to fix those two fundamental issues first!
    Anyway, I suggest you fix those, and if you have any remaining issues, create a new thread with the full information as suggested by the forum guidelines.
