  2. Mixed-Signal Design
  3. AMS simulation questions
  • Subscribers 64
  • Views 16765
Octavian
Octavian over 12 years ago
I have a top level verilog testbench instantiating an analog spectre module (subckt). I can run a transient simulation with the Incissive irun flow but I could not figure out how to do the following:
- sample an internal voltage/current in the analog module and use that in the verilog code to make a decision:
if ( V(I0.I0.I0.analog_node) > 1 )
// startup is done
 - set the voltage on an internal analog node from the verilog code.
 - specify the simulation end time from verilog only. I have a $finish statement in verilog but the simulation does not run without a tran statement in the analog code. For now I just made the tstop paratemeter for the tran statement very large so the $finish gets called much earlier, but I'm wondering if there is a better way.
 Any help is appreciated.
  • Octavian
    I made some progress on this but I could still use some help. I gave up on using a VerilogD testbench (due to limited support for real numbers) and focused instead on SystemVerilog and Verilog-AMS.
    The out of module refereces (OOMR) work with the setup listed below. It seems that everything is fine and E2R/R2E conversion blocks are inserted if I use a wreal buffer module, but only logic levels (E2L/L2E conversions) are passed if I use assign statements. Does anybody know how to force the the E2R/R2E conversions for OOMR's and assign statements?
    Also I used VerilogD testbenches with other co-simulation tools previously and they had built in tasks (i.e. $snps_get_voltage) for OOMR access accross simulation domains. Is there something equivalent available in the Cadence flow?
    top.vams
    module real_buff(i,o);
        output wreal o;
        input wreal i;
        assign o=i;
    endmodule
    module testbench ;
        wreal rtop;
        wreal rmid;
        real src;
        wreal sense;
        assign rtop = src;
        //assign sense = rmid;
        //assign sense = I0.rmid2; // does not work (assigns logic connection)
        //real_buff b2(.i(I0.rmid2), .o(sense));
        //assign I0.rtop2 = src; // does not work (assigns logic connection)
        real_buff b3(.i(src), .o(I0.rtop2));
        real_buff b2(.i(I0.rmid3), .o(sense));
        res_ladder I0 (.rtop(rtop),.rmid(rmid));
        initial begin
            src=0.0;
            #10 src=3.0;
            #10 src=1.0;
            #10;
            $finish;
        end
        always @(sense) $display("%t: sense has changed to %0f", $time, sense);
    endmodule
    res_ladder.scs
    subckt res_ladder rtop rmid
    r1 (rtop rmid) resistor r=10k
    r2 (rmid rmid2) resistor r=10k
    r3 (rmid2 0) resistor r=10k
    r4 (rtop2 rmid3) resistor r=10k
    r5 (rmid3 0) resistor r=10k
    ends
    amscf.scs
    timeDom tran stop= 30u
    include "res_ladder.scs"
    amsd {
            portmap subckt=res_ladder
            config cell=res_ladder use=spice
            ie vsup=1
    > irun -access +rw -solver spectre  -timescale 1ns/100ps -iereport -autospiceoomr amscf.scs top.vams
