  2. Mixed-Signal Design
  3. Pin labels in Virtuoso from Encounter OA
  • Subscribers 64
  • Views 20000
nevsan
nevsan over 12 years ago
I'm trying to get a mixed signal environment up and running. I can save the Encounter database to OA using an interoperable PDK (standard cell/routing tech lef in OA referencing base PDK). The layout looks fine in Virtuoso, but one thing that I am missing is pin labels (the kind I need for LVS). The wierd thing is that if I stream the design out from Encounter to GDSII and then stream it in, all of the pin labels are there on the proper layers. They just don't show up in the OA layout (doesn't matter whether I use saveDesign or oaOut).
  • nevsan
  • AndreasLenz
    AndreasLenz over 12 years ago
    If I understand you right you create labels in Virtuoso but they are not visible in EDI open the Design.
    On which purpose do you create the labels?
    In EDI direct after startup you could set the setOaxMode with the option -textPurpose <purpose name>
    -textPurpose purpose_name
                  Specifies  the  purpose  name that will be used when text labels
                  are written.
                  By default, any text label created in EDI System (typically  via
                  the   add_text   command) is automatically mapped to the drawing
                  purpose. Use the -textPurpose parameter to map the  text  labels
                  to a user-defined purpose.
                  Default: drawing
    Or is the issue to create Labels?
    If you login into support.cadence.com search for the solution with the ID Number: 20070208.
    Kind Regards,
    Andreas
  • nevsan
    nevsan over 11 years ago
    Here's what I settled on for an export script that has pin labels
        setOaxMode -textPurpose label
        set labels {}
        set orientations [dict create R0 R270 R90 R0 R180 R90 R270 R180]
        foreach term [list {*}[dbGet top.terms] {*}[dbGet top.pgTerms]] {
            lappend labels [add_text -label {*}[dbGet $term.name] -height 0.5 -alignment centerLeft \
                                -pt [dbGet $term.pt] -layer [dbGet $term.layer.name] \
                                -orient [dict get $orientations [dbGet $term.orient]]]
        # Stream into OA
        oaOut lib cell view -autoRemaster
        # Remove labels
        foreach label $labels {dbDeleteObj $label}
  • AndreasLenz
    AndreasLenz over 11 years ago
    If you see an issue please file a Service case at support.cadence.com.
    Kind Regards,
    Andreas
  • nevsan
    Thanks. Given what I've read, it seems to be more of a missing feature than a bug. I'm really quite surprised that this little piece of the Mixed Signal interoperability puzzle isn't naturally part the EDI => Virtuoso workflow. We can't LVS the block by itself without pin labels and I can't get my layouters using Layout-L to connect to it correctly without pin labels. Hopefully my script will help out others that want a more complete export out of EDI and into OA.
