  2. Mixed-Signal Design
  3. netlist differences
  • Subscribers 63
  • Views 15054
netlist differences
Ram123
Ram123 over 11 years ago
I heard from a friend that every-time you run a design, a new netlist is created. How is this netlist different each time even if the circuit is same?
  • AndreasLenz
    AndreasLenz over 11 years ago
    I assume you mean the netlist changes in Encounter. The netlist gets optimized to fix timing, HFN,...
    The functionality doesn't change during optimization. This is a normal behavior in digital design implementation.
    At each step you verify the netlist against the golden one using Conformal.
    Kind Regards,
    Andreas
  • Ram123
    Hi Andreas,
    Thanks for your detailed reply! I was wondering how do you figure out the netlist has changed for the same circuit just by looking at the netlist code?
     Ram
