  2. Mixed-Signal Design
  3. ultrasim - failing on error - parameters previously red...
  • Subscribers 64
  • Views 1559
ultrasim - failing on error - parameters previously redefined
ramp78
ramp78 over 11 years ago
Hi all,
In spectre, there is an options statement - redefinedparams=ignore will ignore this parameters previously defined parameters error  - worked fine in spectre.
In ultrasim - I tried the same options - it failed, is there any equivalent options statement for the same to ignore this error in ultrasim
Ramesh
  • Uma Sankar
    Uma Sankar over 11 years ago
    Hi Ramesh,
    Starting from MMISM 7.1 the same option (redefinedparams=ignore) works for Ultrasim also.
    What is the Ultrasim version you are using?
    With Regards,
    Uma Sankar
