  2. Mixed-Signal Design
  3. run index as a parameter in montecarlo simulation
  • Subscribers 64
  • Views 14505
GFernandez
GFernandez over 11 years ago
Hi, I'm testing and ADC in ADEXL. To get the transfer curve, I use a slope at the input with a transitory analysis, then, a module written in verilog-ams takes the value at the input and the code at the output and writes it down on a csv file.
In order to do the same on a montecarlo simulation, it would be great to get de run index number of the present montecarlo simulation in order to create a unique csv file for each simulation.
Is there any way to get this number a simulation time? Is there a better way to perform this task?
Thank you very much, any bit of advice will be greatly appreciated.
Gerard.
