  2. Mixed-Signal Design
  3. ncsim: *E,SST2ER: SST2 interface error: Invalid argument...
  • Subscribers 63
  • Views 5929
FormerMember
FormerMember over 11 years ago
I'm able to run all the RAKs from Cadence but currently the mixed-signal simulation that I'm running crasses with the message:
ncsim: *F,INTERR: INTERNAL EXCEPTION
Observed simulation time : 0 FS + 2
Immediately it calls csi-ncsim, and I cannot even debug.
Any thoughts of what might be the problem? I'm running Incisive 14.2, IC161, MMSIM141,  all last versions.
Thanks.
    You should contact customer support if you're getting a crash.
    • Vote Up -1 Vote Down
