  2. Mixed-Signal Design
  3. spice netlist in cadence
  • Subscribers 64
  • Views 16302
mohamedly
mohamedly over 11 years ago
Hi all,,,
I need to use a spice netlist in cadence and I created a symbol and changed its CDF to referring to the subcircuit file.
my question is about the symbol should I build an equivelant components in the spice netlist in cadence schematic view to create a symbol or just choose any present symbol and change its CDF.
I mean if my netlist describe a circuit with supply voltage and resistances and capacitance should I build the same circuit in the schematic view?
I hope my question is clear
thanks a lot in advance.
    You may have posted the same question twice (although your other question didn't seem to make much sense). See:
    http://community.cadence.com/cadence_blogs_8/b/rf/archive/2009/01/07/tip-of-the-week-how-to-simulate-a-subcircuit-netlist-with-spectre-in-ade
