  2. Mixed-Signal Design
  3. specifying libraries to exclude during compilation
  • Subscribers 64
  • Views 15670
HPetrow
HPetrow over 11 years ago
I have compiled some SystemVerilog files to virtuoso Library as modules using the ncvlog -use5x option.
Now I should tell the AMS designer not to include this library during the compilation. In the cadence help files it shows that the Hierarchy editors AMS Options -form should have a field to define these. But when I open virtuoso and go to this form I am unable to see the options.
How can I let AMS designer to know not to include these files?
    Which version of Virtuoso are you using (Help->About in the CIW should tell you the subversion)? Also, are you running from ADE, and if so, which netlister are you using (Cell-Based, OSS or Unified Netlister (UNL))?
  • HPetrow
    thank you for the reply.
    I am using the version IC6.1.6-64b.500.8. And yes I am running from ADE with the OSS netlister.
    BR
    -Henri
