  2. Mixed-Signal Design
  3. need help with SV resolution function
  • Subscribers 64
  • Views 14752
golanp
golanp over 11 years ago
Hi
new here ...
I need help with resolution function.
Only tried to implement the example given in the IEEE SV 2012 spec section 6.6.7
I wrote the following small code:
// user-defined data type T
 typedef struct {
    real field1 ;
    bit field2  ;
 } T ;
 // user-defined resolution function Tsum
 function automatic T Tsum (input T driver[]);
    Tsum.field1 = 0.0 ;
    foreach (driver[i])
<span style="font-weight:bold">       Tsum.field1 += driver[i].field1;
</span> endfunction
 module drv (output T drv_out) ;
 endmodule
 module top ();
    nettype T wT                     ; // an unresolved nettype wT whose data type is T
    nettype T wTsum with Tsum ; //
    wT            no_rf   ;
 //   wire_with_rf  with_rf ;
    drv drv1 (
        .drv_out(no_rf)
   // drv drv2 (
   //     .drv_out(no_rf)
    drv drv3 (
        .drv_out(with_rf)
    drv drv4 (
        .drv_out(with_rf)
 typedef struct {
    real field1 ;
    bit field2  ;
 } T ;
    Tsum.field1 = 0.0 ;
    foreach (driver[i])
 endfunction
    wire stam;
 endmodule
and I get the following ERROR:
> which ncverilog
/nfs/iil/eda/tools/cadence/incisive/14.10.013/linux_2.6.16_x86-64/tools/bin/ncverilog
[176]icsl2618:/<6>Mixed_signals/SV/DFE_TB> ncverilog resolution_function_try.sv -sv -sysv +access+rwc +gui
ncverilog: 14.10-s013: (c) Copyright 1995-2014 Cadence Design Systems, Inc.
ncverilog: *N,SNPREC: The existing contents of the environment SPECMAN_PRE_COMMANDS will only be passed on to the simulation phase (conf gen -default_generator=IntelliGen;#ifndef CDN_UVC_USING_INTELLIGEN {define CDN_UVC_USING_INTELLIGEN;}).
file: resolution_function_try.sv
ncvlog: *E,SVRFINV (resolution_function_try.sv,23|28): function or class method does not conform to resolution function requirements.
ncvlog: *E,SVRFST (resolution_function_try.sv,11|17): static variable not allowed in resolution function.
ncvlog: *E,SVRFST (resolution_function_try.sv,11|37): static variable not allowed in resolution function.
module worklib.top:sv
errors: 3, warnings: 0
ncverilog: *E,VLGERR: An error occurred during parsing. Review the log file for errors with the code *E and fix those identified problems to proceed. Exiting with code (status 1).
Can someone help ?
1
COMMENT
HIDE ▲
BTW
line 11: Tsum.field1 += driver[i].field1
line 23: nettype T wTsum with Tsum ;
I am using cadence ncverilog
