  2. Mixed-Signal Design
  3. Using pPar("") in AMS simulation
  • Subscribers 64
  • Views 4759
designguy
designguy over 11 years ago
I currently have a problem trying to pass instance parameters to a spectre model by using pPar("[parameter_name]") when I run AMS simulations.  My virtuoso version is virtuoso 6.1.6
Here are the 2 following scenarios:
1) If I set  the parameter_name = some number in my ADE-L state and run the simulation, the instance parameter with "parameter_name" is set to 0.
2) If I set the parameter_name = some number directly on the instance schematic in the Virtuoso schematic editor, the instance parameter is set correctly in the netlist.
This is a problem I only encounter while running AMS simulations.  I do not have the same problem when running a pure spectre simulation.
Please let me know what I can do to resolve this problem (is there a simple work around for using pPar with AMS).
    Hopefully you've contacted customer support by now, because I can't imagine what the problem might be without seeing the data. pPar() should work fine with AMS too.
