  2. Mixed-Signal Design
  3. [SOLVED] unable to compile with genvar variable in veri...
  • Subscribers 64
  • Views 23199
[SOLVED] unable to compile with genvar variable in veriloga
msharma
msharma over 11 years ago
I am writing a verilog-ams model for an 8 bit ADC. The code is derived from section 4.5.8 example 2 of vams2.3.1 reference. However, the use of genvar gives an error:
Error found by spectre during AHDL compile.
    ERROR (VACOMP-1149):
        "/.../adc_8bit/veriloga/veriloga.va", line
        27: Genvar loop evaluation failed. Check whether `/usr/bin/perl' is
        available.
    ERROR (VACOMP-1816): Exiting AHDL compilation.
Internal error found in spectre during AHDL compile, during generation of
        Artist DPLs.
Encountered a critical error during simulation. Submit a Service Request via
        Cadence Online Support, including the netlist, the Spectre log file,
        the behavioral model files, and any other information that can help
        identify the problem.
    FATAL (SPECTRE-18): Segmentation fault.
/uusoc/facility/cad_tools/Cadence/MMSIM_13.11.176_lnx86/tools/bin/spectre[80]: .: line 1076: 22896: Abort
The error is in the first line that uses genvar, and complains about "usr/bin/perl". Any clues to fixing this?
Here is my complete code
`include "constants.vams"
`include "disciplines.vams"
`timescale 1ns / 1ps
module adc_8bit (out, in, clk, vref, avdd, agnd, ibias) ;
input in, clk, vref, avdd, agnd, ibias;
output [0:7] out;
electrical in, clk, vref, avdd, agnd, ibias;
electrical [0:7] out;
real vdd, ref;
real sample;
integer result[0:7];
//integer i;
genvar i;
analog begin
 vdd = V(avdd) - V(agnd);
 ref = V(vref) - V(agnd);
        @(cross(V(clk) - vdd/2, +1)) begin
                sample = V(in);
                for ( i = 7; i >= 0; i = 1-1) begin
                        if (sample > ref) begin
                                result[i] = 1;
                                sample = sample - ref;
                        end
                        else begin
                                result[i] = 0;
                        end
                        sample = 2.0*sample;
                end
                        V(out[i]) <+ transition(result[i], 0, 10n);
                end
                V(out[7]) <+ transition(result[7], 0, 10n);
                V(out[6]) <+ transition(result[6], 0, 10n);
                V(out[5]) <+ transition(result[5], 0, 10n);
                V(out[4]) <+ transition(result[4], 0, 10n);
                V(out[3]) <+ transition(result[3], 0, 10n);
                V(out[2]) <+ transition(result[2], 0, 10n);
                V(out[1]) <+ transition(result[1], 0, 10n);
                V(out[0]) <+ transition(result[0], 0, 10n);
        end
endmodule
    First of all, please read the forum guidelines. These ask you not to post the same question in multiple forums. I will answer your issue here and add a cross-reference in the other post.
    The cause of the problem (unfortunately it gives a rather cryptic message) is that your for loop is incorrect. You have:
    this means that you have an infinite loop. because i is set to 0 at the end of each iteration and so will never end. A genvar causes it to attempt to expand the loop at compilation time (or elaboration time - not entirely sure which off the top of my head) and so it can't succeed. The message about perl is misleading in this case.
    In the code as it stood, you could have left it as an integer rather than a genvar because there's no need for it to be a genvar (only the commented out part needs a genvar). However, that reveals that  you have an end statement missing. This needs to end the begin for the @cross statement, because the contribution statements need to be outside of the @cross block as they need to be present on every iteration, not just during the cross events. If you'd fixed the missing end and left it as an integer rather than genvar, you'd have seen it hang at simulaton time because of the infinite loop.
    Anyway, by fixing the for loop and uncommenting the for loop around the contribution statements (and fixing the for loop there too as that was also incorrect) and inserting the missing end, I get:
    output [0:7] out;
    real vdd, ref;
    real sample;
    //integer i;
    genvar i;
    analog begin
                    sample = V(in);
                    //for ( i = 7; i >= 0; i = 1-1) begin
                    for ( i = 7; i >= 0; i = i-1) begin
                                    result[i] = 1;
                            end
                            else begin
                                    result[i] = 0;
                            end
                    end
            end
            end
            end
    endmodule
    which works correctly.
  • msharma
    Thanks for the detailed answer! I have noted the inpropriety about double posting.
