  2. Mixed-Signal Design
  3. AMS-Sim
  • Subscribers 64
  • Views 15027
AMS-Sim
MARON
MARON over 10 years ago
Good day!
I have a question in AMS Simulation.
Right now I simulate using ADE. From the results folder, it created a psf and netlist subfolder.
In the netlist subfolder, I started using Standalone Simulation. My command on the shell is simply  ./runSimulation
After the simulation, why is that the contents of the irun.log using Standalone simulation is not the same with the irun.log using ADE?
In the Standalone simulation the contents are very few compared to the one using ADE. And there is no percentage of completion.
Should I edit the content of the runSimulation? What simulation option should I add?
Thank you very much in advance.
    I moved this to a more appropriate forum (feedback and suggestions was not the right place).
    Given that ADE only invokes the simulation by running the runSimulation script it creates, I can't really see how this can happen.
    Which version of irun are you using (irun -version)?
