  2. Mixed-Signal Design
  3. ncelab: *N,DLWTLK
  • Subscribers 64
  • Views 1527
ncelab: *N,DLWTLK
nikiva
nikiva over 10 years ago
I am having a problem when running the AMS simulation and when there is a single transistor from the PDK in the testbench.
The error that pops up in the log is:
ncelab: *N,DLWTLK: Pausing until a shared lock can be established on library 'std'.  Another process may be accessing the library.  Process will resume when the lock is established.
Does anyone have any advice on how to solve this error?
I tried using the nchelp command to explain the error and one of the suggestions was to use ncpack -unlock std to manually terminate the process but I do not have the permission to do so.
