  2. Mixed-Signal Design
  3. include function file in verilog-AMS
  • Subscribers 64
  • Views 18816
Narasimhan90
Narasimhan90 over 10 years ago
In a library I have a few cells for which I have created verilogams views. I am performing similar functions in the various verilogams files. So I included all those functions in a separate file. Here is a snapshot of the file wreal_func.txt (this is just an example to explain what I want exactly)
/////// file start
function real mult;
  input real a,b;
  mult = a*b;
endfunction
function real divi;
  input real a,b;
  divi = a/b;
endfunction
/////// file end
Now in my modules I have used these functions(like for example  assign z=divi(x,y);  )
If I include the file in each module like
module example();
`include "/somepath/wreal_func.txt"
//some code
endmodule
then it works properly.
Is there a way to include this file globally during simulation(like an ADE option) so that I need not include it in each and every module. That too I need to include the file inside each module. If I define it outside a module(similar to constants.vams) it again throws a syntax error.
    Not entirely. There is the vmsTemplateScript capability as described in solution 11457788. However, if you use create cellView from cellView to create the view and use this approach, you don't get the pins - so this is not really a complete solution (there's a CCR for this limitation).
