  2. Mixed-Signal Design
  3. too few terminals given
  • Subscribers 64
  • Views 18083
Karev11
Karev11 over 10 years ago
Spectre seems to find fault with a veriloga model I used and the error message shows as below:
ERROR (CMI-2116) : too few terminals given (15<17) ....
I searched the forum, there are a few thread related, but doesn't seems quite applicable to this case, which is a pure analog testbech with just this one block in veriloga.
I also added the veriloga model as below, main function is to serilize.
Could someone please take a look?
Thanks!
Kev
`include "constants.vams"
`include "disciplines.vams"
module testmod(in,vdd,clk,rstn,out,itest);
input [11:0] in;
electrical [11:0] in;
input vdd,clk,rstn;
electrical vdd,clk,rstn;
output out, itest;
electrical out, itest;
real vdd_v, vth, out_v, rstn_v,itest_v, in_v[11:0];
integer i,k,delay;
analog begin
    vdd_v = V(vdd);
    vth = vdd_v/2;
    delay = 0;
    rstn_v = V(rstn);
      @(cross(V(clk) - vth, 1))
      begin
           if (rstn_v < vth)
          begin
             i = 0;
                 out_v = 0;
          end
       else if (i > 11)
             begin
            i = 0;
                generate k (0,11)
            in_v[k]=V(in[k]);
             end
          out_v = in_v[i];
          i=i+1;
      end
      itest_v=i-1;
      V(out) <+ transition(out_v, 10p, 10p, 10p);
      V(itest) <+ transition(itest_v, 10p, 10p, 10p);
end
endmodule
    Which IC subversion are you using (Help->About in the CIW) and which simulator subversion (this should appear at the top of the spectre log file)?
    Can you show the instance line in the input.scs for the instance of this component?
    Also, can you dump the CDF (Tools->CDF->Edit CDF in the CIW, set to Base, and fill in the libName/cellName for testmod and specify a filename and click on CDF Dump - and then post that here?
