  2. Mixed-Signal Design
  3. computing FFT and SNR using spectrum function
  • Subscribers 64
  • Views 19281
sidz
sidz over 10 years ago
Hi all,
I am working with flash ADC. I wanted to know what is the procedure being followed and what parameters need to be set while simulating FFT in order to find SNR, SNDR, ENOB.
Thank you in advance.
regards,
Siddharth kala
    You should look at using the spectrum assistant in ViVA (covered in the documentation). There's also this application note.
  • Avinash Murugesan
    Avinash Murugesan over 5 years ago in reply to Andrew Beckett
    Dear Andrew, I see that this link is not opening, and requires some authentication. It would be kind if you could post an open source link on the documentation. Thank you.
    Regards
    Avinash M
    ShawnLogan over 5 years ago in reply to Avinash Murugesan
    Dear Avinash,
    The link that you indicate appears to have been updated as I was not able to access it. I believe a link that does function for me with the same information is at:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000009MpV4UAK&pageName=ArticleContent
    You will need a Cadence On-line Support account to view the note.
    Shawn
    Shawn's right - that's the updated version of the app note (the original path doesn't work any more - but I fixed the link in the post in case anyone tries again)>
