  2. Mixed-Signal Design
  3. Difference marker in simvision
  • Subscribers 64
  • Views 23576
SimhanAnalog
SimhanAnalog over 10 years ago
In viva there are ways to check difference between two markers(both dx and dy by pressing key 'a' and key 'b' or key 'm' and key 'd'). Is there a similar functionality in simvision?
    In simvision you can use the left mouse button to set the "cursor" and the middle mouse button to set the "baseline" cursor. If it's analog waveforms you're looking at (which I assume it would be, otherwise the delta isn't going to be that useful), these can be displayed using View->Show Analog Deltas:
    Note that the difference between the two vertical cursors is shown above the legend. Also, the cursors panel (to the left of the waveforms) can be changed to either show the cursor or the baseline values.
    See the deltas on the picture above.
  • SimhanAnalog
    Thanks for your explanation.
