  2. Mixed-Signal Design
  3. Regarding Layout Path
  • Subscribers 65
  • Views 16093
Sattar72
Sattar72 over 10 years ago
Hi : I am working on Virtuoso Layout Editor tool.Version: Cadence 6.1.6.
In Layout window when i press P+F3 to route Metal path. But in my layout window i am getting just Centre line i am not getting Border lines. i Changed my settings but it is not working.Can any one help me...
Thanks & Regards
ssattar
  • AndreasLenz
    AndreasLenz over 10 years ago
    Hello Syed,
    Are you working in L or XL?
    Did you select the Metal layer in the palette and provide a net name (in case you use the options form in L-Tier).
    Kind Regards,
    Andreas
  • Sattar72
    I am working on Virtuoso L. Ya i am doing in this manner only, i select Metal layer and provided net name. I am not getting path.. Thanks & Regards
    ssattar
  • AndreasLenz
    Please contact the Cadence customer support or send me an email to setup a webex to support you. Kind regards, Andreas
  • Charanraj Mohan
    Charanraj Mohan over 10 years ago
    may b u should try to use use Display options (or press E in layout) and decrease the X/Y snap spacing in Grid controls and change Edit to diagonal in Snap modes. :-)
