  2. Mixed-Signal Design
  3. Corner analysis
  • Subscribers 64
  • Views 15315
Corner analysis
Charanraj Mohan
Charanraj Mohan over 10 years ago
I have the corners in XML file format.
I need these in SDB/PCF/DCF file format for corner analysis. How to convert them to these formats from XML ?
Thanks in advance.
    The SDB file is an XML file - so assuming it's following the right schema, this may be what you want... (perhaps it's just not been given the ".sdb" suffix?)
  • Charanraj Mohan
    Thanks Andrew :-)
