  2. Mixed-Signal Design
  3. cdb to oa conversion
  • Subscribers 64
  • Views 32493
Charanraj Mohan
Charanraj Mohan over 10 years ago
Hey,
 I have a library in Cadence 5 and I need to convert it to Cadence 6. For this I do the following in the Command window (Orange window environment) in steps. Consider that my library is 'eva' is original in Cadence 5, HITKIT 3.7 AMS35 and I want to convert this library to Cadence 6 HITKIT 4.10 library.
Steps followed-
1. Create a temporary directory
mkdir $HOME/tmp
cd $HOME/tmp
2. Create cdb and oa directories and change the directory to cdb
mkdir cdb
mkdir oa
cd cdb
3. Create cds.lib file with the following content inside
DEFINE eva /directory_of_eva
4. Put/Copy this file into the cdb directory.
5. Change the directory to oa
cd ../oa
6. Execute cdb2oa to convert the library to oa database
cdb2oa -lib eva -cdslibpath ../cdb
(I assume the converted library file to be in the directory oa)
I get the following error:
ERROR   (CDBOA-500): Cannot translate CDB design library <path>/<name> to
                     OpenAccess because CDB technology library <name> referenced
                     by the CDB design library is not available in the
                     OpenAccess format. Before translating the CDB design
                     library, ensure that all the referenced CDB technology
                     libraries are available in OpenAccess and defined in
                     'cds.lib'.
                      Generated once. The translator stopped because the CDBA
                     library references an attached technology library that does
                     not exist in OpenAccess.
                      Check the source library files and correct the library
                     attachments as required. Ensure that the cds.lib file is
                     present in the current directory and any technology library
                     that is referenced by the current library is defined in the
                     cds.lib file and is available in OpenAccess at the time it
                     is referenced. If the design library is referencing itself
                     as an attached technology library, ensure that there is an
                     appropriate tech.db technology file present in the
                     OpenAccess library directory.
I have done the normal procedure for cdb to oa conversion. Does this imply that I have to also have a cds.lib file in the oa folder with all the design libraries ??
Thanks in advance.
    Yes, in the destination directory you should have a cds.lib with all the reference libraries (e.g. technology libraries) that you need. Otherwise it can't find information about the technology.
    If you were converting everything, you'd convert the leaf level technology libraries first, then build upwards. However, if you already have an OA version of the PDK you should just be able to reference that in the destination cds.lib file.
  • Charanraj Mohan
    Thanks Andrew for your quick reply. I used the GUI conversion tool to do the conversion. I get the following warnings.
    Message Summary:
    WARNING (CDBOA-406): Directory <path>/<name> is in a cellview. The directory
                        and its contents will be copied to the destination database
                        but will not be translated.
                         Generated once. Neither CDBA nor OpenAccess supports
                        directories in cellviews. The directory and its contents
                        are copied to the destination library but are not
                        translated. This could mean that you end up with CDBA data
                        in the OpenAccess version of your library. Check the
                        directory in question. If it contains data that needs to be
                        translated, correct the source data so that it conforms to
                        legal directory structure conventions and then run the
                        translator again.
    WARNING (CDBOA-605): For cellview <path>/<name> the view type implied by the
                        file name (<viewtype>) differs from the view type held in
                        the database (<viewtype>). Creating a view of type
                        <viewtype> in OpenAccess.
                         Generated 8 times. The translator has encountered a CDBA
                        cellview for which the view type stored in the cellview
                        data file differs from the view type implied by the
                        cellview file name. OpenAccess expects a cellview filename
                        to reflect the stored view type. The translator identifies
                        conflicting view type information and fixes it by changing
                        the cellview filename to agree with its stored view type.
                         For example, a CDBA cellview with the stored view type
                        maskLayout to be called symbol.cdb. This would be
                        translated into an OpenAccess cellview of type maskLayout
                        called layout.oa.
                         To prevent these warnings from being generated, modify
                        your CDBA data to ensure that the view type implied by the
                        filename matches the view type stored for the cellview. For
                        example, if the filename is sch.cdb, then the view type
                        should be schematic.
    WARNING (CDBOA-649): There is a mismatch between the default values of CDF
                        param and pcell superMaster param. The CDB2OA translator
                        will continue. However, for improving data translation
                        match the default value of the CDF param with the pcell
                        superMaster param in CDB data.
                         Generated 3 times.
    Is there a way in the settings of  'CDB to OpenAccess Translator' to avoid these errors, though their severity are low and I used different directory during translation by rule ??
    I also noted this. When I open the top cell of all my designs in the translated library, I can see a windows popping and it tells--Missing Masters: The following masters are used in this cellview, but cannot be found in your search path:
    Library       Cell        View
    (I have five cell listed here)
    & when I look into the errors in my top cell-schematic (by pressing g), I can see the comment  'Error: unbound instance--Library_name cell_name symbol (basic opin symbol).
    How to avoid these kind of errors during translation ? there should be few settings in the GUI tool-'CDB to OpenAccess Translator' such that a library with 'no error' in cadence 5 is being converter to cadence 6 with same 'no error'.
    Thanks in advance.
    The final problem simply means that you didn't include all the relevant libraries (e.g. the basic library which is in the IC61X installation) in your destination cds.lib file. You don't need to translate these, but you do need to reference them.
    You'd want to put something like:
    analogLib $(inst_root_with:tools/dfII/bin/virtuoso)/tools/dfII/etc/cdslib/artist/analogLib
    basic $(inst_root_with:tools/dfII/bin/virtuoso)/tools/dfII/etc/cdslib/basic
    in your cds.lib file.
    I don't think there's a way to suppress warnings. The warnings are reasonable - telling you about differences in what is supported between CDB and OA. In terms of errors - that's just a matter of you ensuring the data setup is correct. There are occasions (here and there) where something that was done in CDB and tolerated can't be supported in OA - but these are explained at the time.
    Anything you're unclear about you should talk to customer support.
  • Charanraj Mohan
    Thanks Andrew once again :-)
    The reason behind the errors was the following:-
    During CDB to OA translation, a library named 'IOLIB_ANA_4M' got changed to 'IOLIB_ANA_4M_local'. Similarly, another library name 'IOLIB_4M' changed to 'IOLIB_4M_local'. This happened only in the schematic and in cds.lib file, it is correct.
    I metaphor these kind of mismatches to cases like- when we do PEX extraction using CALIBRE, the calibre file (or the parasitic extracted file) possess  port names in capital letters, even though we give the names in small letters in the schematic/symbol  and may be with little change in I/O/IO pin configuration from those in schematic/symbol. And later we need to 'Check and safe' to correct errors.
    Unless a justification is given to such cases, the conversion (a Cadence tool) and extraction (a Mentor Graphics tool) tools are to be subjected to improvement and bug-fixed.
    I have no idea what problem you're describing above.
    CDB to OA Conversion is something that has had many fixes over the years - it was very important to make it pretty robust. It's been used a huge number of times since we first introduced OA versions of the tools about 12 years or so ago. However, it does require valid data and setup to use it properly.
    If there are bugs, you need to report them with clear information as to what went wrong. I don't get that from above because you didn't really explain the specifics - so please go to customer support.
