  2. Mixed-Signal Design
  3. divide by zero warning
  • Subscribers 64
  • Views 15205
Charanraj Mohan
Charanraj Mohan over 10 years ago
 I have a warning like this when I use diodes from ahdlLib. How to avoid this warning ?
WARNING: "/cad/CADENCE_14/IC_6.1.6_080/tools/dfII/samples/artist/ahdlLib/diode_simple/veriloga/veriloga.va" 39: I44.I33: divide by zero is found.
    Which simulator version are you using? Can you reproduce it with a simple test bench that you can share here (post the input.scs)? I just tried a simple testcase and it worked fine with no warnings.
