  2. Mixed-Signal Design
  3. Cell views & plot in cadence
  • Subscribers 64
  • Views 3916
Charanraj Mohan
Charanraj Mohan over 10 years ago
1. What are the difference between schematic and schematic_sim in cadence ?
For example, I have schematic_A which has a symbol_B. Symbol_B further has some schematic with a symbol_C of a verilog-A code and schematic_A is again made as a symbol_A.
The hierarchy is something like this: Symbol_A-->Symbol_B-->Symbol_C
When I desend symbol_A in my main schematic to look what is inside, Cadence gives me option to open in the following:-
a. Schematic
b. Schematic_sim
c. Layout_int
d. Extracted
e. Schematic_lvs &
f.  Symbol
When I desend & open the schematic_A by schematic the Symbol_B doesnot appear. But when I open it with schematic_sim the Symbol_B appears. I want to know the reason of it or an explanation of where to use Schematic and Schematic_sim.
2. Similarly, where to use spectre, spectreS and symbol of the models in the FDK and their compatibility.  For the fact I noticed that, as we go down the technology spectreS is missing. For example in UMC 130 nm and 28nm technologies the spectreS view of the module is unavailable, whereas in AMS 0.35um we have it. Is it something like spectreS is an old cell view format ?
3. Is it possible in Cadence to plot two different plots from different technology ?
Thanks in advance.
    First of all, there is no tool called "Cadence". That's the name of the company, not the tool. To briefly answer your questions:
    1. No idea. It depends on what has been put in the views "schematic" and "schematic_sim". View names can be called whatever you want, and so the contents of these views is entirely dependent upon whoever created them. We have no convention for views called "schematic_sim" - you'd have to ask whoever created them. I suspect that one is the physical representation of the view, and the other has a different model for simulation - but that's just a wild guess based on the names - as I said, you would have to ask whoever provided the two views.
    2. spectreS has been obsolete since IC443 (released in about 1999/2000) and has not existed in the tools since IC610 (2006). So it's hardly surprising that spectreS views don't exist. The "spectreS" view and simulator was an old "socket" simulator which used cdsSpice as a pre-processor before running the simulation in spectre; the "spectre" view/simulator in ADE was introduced in IC443 as a direct interface between Virtuoso and the simulator without using cdsSpice as a pre-processor. Given that it's been around for at least 17 years, there really is no good reason to try to use an ancient interface that isn't even available in any release of the software from the last 10 years!
    3. Yes. We even have a capability in ADE XL called "MTS" (Multi-technology support) which allows you to simulate devices from two different technologies together (it scopes the models so that they only apply to parts of the design hierarchy, which solves the problem if the model names are the same for two different technologies). That may not be what you want, but simply plotting results from two different simulations is even easier and I assume you could have just tried that yourself.
  • Charanraj Mohan
    thanks Andrew :-)
    I used the word 'Cadence' instead of 'spectre', as we are habituated to say likewise in our workplace. I agree and know its not the apt one.
    I came to know that, if we are not using any symbol in the layout, that we used in schematic, then we need to use 'schematic_sim' instead of 'schematic', so that the check is done for remaining except that symbol.
    It would be very helpful if there is a guide/tutorial for using 'Multi-technology support' in ADE XL. Can you refer me any ?
    A search in cdnshelp (via the Help menus in virtuoso) for those keywords "multi technology support" or "MTS" would find it. It's actually in the Virtuoso Analog Design Environment GXL User Guide, and has a chapter to itself. Whilst it's under ADE GXL, it's actually available with just an ADE XL license (or Assembler/Explorer in IC617).
  • Charanraj Mohan
    thanks Andrew. I tried it. In fact, it isn't elaborate.
    Am afraid if you are referring to the process parameters change like temperature, etc. To be very specific, I open Cadence for the following in difference workspaces-
    1. Technology A- AMS 0.35um
    2. Technology B- UMC 180nm
    3. Technology C- ST 130nm
    4. Technology D- FDSOI 28nm
    Say, I have a simple inverter in all the technologies and they are saved in their respective directories. Now I want to have all the plots (say, Drain current- Id_AMS, Id_UMC, Id_ST & Id_FDSOI for a simple DC sweep of gate voltage) in same graph. Can this be done using 'Multi technology simulation'. If so, can you refer/recommend me any additional references ?
    Using MTS would require you to have all four technologies running in the same session. That might be challenging, although if they're different foundries it may not be too bad as they wouldn't be so likely to clash. Even if you did this, I'd recommend creating the schematics for each in an environment that only had one PDK available to avoid the risk of clashes, and then create a schematic with the four inverters present.
    The MTS documentation that I pointed you would tell you how to point at the model files for each of the different instances - and you'd have to simulate in ADE XL.
    However, since you're really doing this for comparison reasons rather than really needing to simulate them together, wouldn't it be simpler to run your four simulations and then use the ViVA results browser to open the results from each of the four simulation results directories, and then plot them together on the same graph? That's easy enough to do... certainly doesn't need a tutorial to do it (nor does MTS, to be honest).
