  2. Mixed-Signal Design
  3. unable to measure/plot current
  • Subscribers 64
  • Views 6311
Charanraj Mohan
Charanraj Mohan over 10 years ago
 I am using analog circuits, but could not plot the current. First, before simulation I couldn't mark the current node directly or even after adding a 0V dc source. When I try to do plot the currents after simulation in either way i.e. directly and by adding a 0 V source, it did not work.
All time I get a warning 'no "IT" data for node'.
Even I tried this: in ADE Outputs->Save all. In this enabling 'All' in the 'save device current'. And then ran the simulation. But it's not working. Can I know how to plot currents in my circuits ??
I am using DFWII IC6-HIT KIT 4.10.
Thanks in advance.
    Please describe:
    1. Which exact subversion of the IC tools you're using (Help->About in the CIW will tell you this)
    2. The precise steps that lead to the 'no "IT" data for node' message - I'm not sure I recognise that.
    Have you tried using Outputs->To be saved->Select on design (might say schematic) and then click on the terminals you want the current saving for?
  • Charanraj Mohan
     Thanks Andrew. I am using IC6.
     I found the reason. A cell view i did not add in the view list of ADE-environment. I was using that cell in a new different view. So, only I couldn't select the output. Later, when I updated the view list, I was able to select for output.
    I should point out that "IC6" (or rather IC6.1) came out in 2006 and there have been 8 major releases of IC61X over the last 10 years (IC6.1.0 -> IC6.1.7), with lots of hotfix versions of each along the way.
    So for future reference, please be precise about the version you're using. 10 years is a long time in software terms - a lot changes in that time.
    Anyway, this turned out to be user error - at least you understand the problem now.
    Kind Regards,
