  2. Mixed-Signal Design
  3. pspice igbt model template
  • Subscribers 64
  • Views 16190
Ninja17
Ninja17 over 10 years ago
hi guys i am trying to make a new pspice model using a template i started going through the automated process of selecting a symbol for a part which was ok but when i compiled it  when i would click on the symbol it gives me the error no template found and i noticed when building the part it was giving me a error of stating no template found in pspice ini could somebody please help
heres the error log
STATUS: PSpice Schematics to Capture translator (17.0.0.d001)
STATUS:
STATUS: Translator started at Thursday, July 07, 2016 15:44:20
STATUS: C:\Cadence\SPB_17.0\tools\bin\sch2cap -f "C:\mylib\myigbt.lib" -o "C:\mylib\myigbt.olb" -i .\cdssetup\OrCAD_PSpice/17.0.0/PSpice.ini
INFO(ORSCH-1029): Using existing library 'C:\mylib\myigbt.olb'.
ERROR: [S2C3467] Template part library not defined in PSpice.ini file, section [Model Editor], item BaseSymLibPath
ERROR: [S2C3471] Base part library does not exist
STATUS: Translator stopped at Thursday, July 07, 2016 15:44:20
STATUS: 2 Error messages, 0 Warning messages
    This post is in the wrong forum. Due to a (hopefully temporary) issue with the forums, I can't move it into the right forum, which is the "PCB Design" forum.
    So I suggest you re-post your question in the PCB Design forum where you are far more likely to reach an audience who can respond.
