  2. Mixed-Signal Design
  3. hi pspice
  • Subscribers 64
  • Views 14941
hi pspice
Ninja17
Ninja17 over 10 years ago
hi have built a citcuit in pspice a regulator circuit with pass transistors for more current i am using igbts but when i run a smoke analysis its tells me the max power dissipation is is to high for the igbt's but its only 24 watts when the max power disipation is 200 watts according to the datasheet but in the rated column is states it is rated at 3.669 watts so i went into the model editor and tried a few values in the power dissipation column and max juction temperature but that rated value would not change when i altered the parameters of the igbt so i don't know whats going on please could someone help i am desperate thanks
    This post (along with your previous one) is in the wrong forum. Due to a (hopefully temporary) issue with the forums, I can't move it into the right forum, which is the "PCB Design" forum.
    So I suggest you re-post your question in the PCB Design forum where you are far more likely to reach an audience who can respond.
