  2. Mixed-Signal Design
  3. No PSF file created by ADE-XL ?
  • Subscribers 64
  • Views 15317
MarkGr15
MarkGr15 over 10 years ago
My co-worker is running a simulation, and he gets measurement results in the ADEXL results tab, however, there is no waveform data.  Therefore, we can not view the simulation waveforms.  He has
all nodes being saved, and it is supposed to save as psfxl.
When I go to the psf directory, that would normally have the psf file to open and view, there is nothing there.
Any ideas ?
thanks
Mark
    Check in ADE XL what it has set for Options->Save. Is the "Save Simulation Data" checked? (the results would get deleted after any scalar values have been computed if this is unchecked).
    Is the "Use Local Simulation Results Directory" checked? If so, it would store the simulation results on a local directory on any remote machine (for performance) and then clean it up when it's done.
