  2. Mixed-Signal Design
  3. Where can I find Virtuoso schematic editor user guide?
  • Subscribers 64
  • Views 25434
veriftb
veriftb over 9 years ago
Tried googling, searching/browsing in cadence website. No luck. Please help. Also a pointer to tutorials available will be appreciated.
Rakesh.
  • AndreasLenz
    AndreasLenz over 9 years ago
    Hello Rakesh,
    You could could open the user guide direct from the schematic editor under the Help menu.
    Another way is to login at support.cadence.com and search for the user guide. Select the version you use and open the link.
    Tutorials are available at < your virtuoso installation dir>/tools/dfII/samples/tutorials/ directory.
    Rapid adoption kits (RAK) are available at support.cadence.com - Resources - Rapid Adoption Kits and provide a very good example to dedicated features. You could download the RAK document and database and you could run in your environment using your own license.
    Hope this answer your question.
    Kind Regards,
    Andreas
  • veriftb
    Thanks. I was able to get the userguide at the support.cadence.com site.
