  2. Mixed-Signal Design
  3. using an expression
  • Subscribers 64
  • Views 14583
using an expression
Charanraj Mohan
Charanraj Mohan over 9 years ago
I am using an expression like this, (2.4 - cross(VDC("/out") 2.4 1 "either" nil nil)), which means the I get the value of y exactly at 2.4 in x-axis, which is finally subtracted from 2.4. This gives/calculates a value for me in the 'value' column of ADE outputs.
Now, i am interested to replace 2.4 with a signal in my simulation. Say, the signal is net028.  I tried something like this,
(VDC("/net028") - cross(VDC("/out") VDC("/net028") 1 "either" nil nil))
and
(VT("/net028") - cross(T("/out") VDC("/net028") 1 "either" nil nil))
but i did not get the value/result :-(
I have three queries,
1. How to use a signal in place of 2.4 in the above expression.
2. I am also interested to do a parametric sweep of that signal and plot it, may be if possible in wave. Is it possible ?
3. As I am playing with low values, is it possible to use cross function with atleast 6 decimal round off ?
Thanks in advance.
