  2. Mixed-Signal Design
  3. unable to plot dB20
  • Subscribers 64
  • Views 18961
unable to plot dB20
Charanraj Mohan
Charanraj Mohan over 9 years ago
I am doing a common mode voltage AC analysis of a 2 stage OPAMP. When I plot the AC phase and magnitude, i get the following error.
Unable to plot expression <dB20((VF("/out") / VF("/in1")))>
because it does not evaluate to an object that can be plotted, like a waveform or
parametric wave. See the Visualization & Analysis Tool documentation for information
about the types of objects that can be plotted in Visualization & Analysis Tool. Only
the expressions that evaluate to those objects can be plotted.
*Warning* Wave11 is not a waveform object that can be displayed and
will be DELETED automatically.
I also get this error in red color in the beginning -
*Error* Evaluating expression (dB20((VF("/out") / VF("/in1"))))
*Error* ("eval" 0 t nil ("*Error* eval: unbound variable" gridResol))
But I am getting the phase plot and it is reasonably ok. How to overcome this error ? I click the output and the one of the inputs.
thanks in advance.
    This might just be because of the extra unnecessary parentheses you have in the expression. SKILL has a problem if you use more than one set of matching parentheses as it confuses the parser (which can handle C-like and LISP-like expressions). So try changing to:
    dB20(VF("/out") / VF("/in1"))
    and see if that helps. I am (of course) assuming you've saved the signals involved in the expression - judging by the fact that you can plot the phase (you didn't give the expression for that) I would imagine you've done that.
