  2. Mixed-Signal Design
  3. verilogA inlude search path
  • Subscribers 64
  • Views 16589
AdapSamp
AdapSamp over 9 years ago
Dear All
I have a couple of questions about verilogA, one on search path for include files and the other on using veriloga model without creating a veriloga view.
First, related to the search path for the includes, how would I set a list of paths to search for the include files. On a related note, does referencing a path as
`include"~/somepath"
not valid?  It gives a syntax error when attempted to do so.
Secondly, suppose I have a module, say resistor in a veriloga file named resistor.va. How may I associate an existing symbol view of a cell with  this veriloga module instead of creating a veriloga view. For example, if I instantiate the symbol of the cell under question in a schematic and netlist it, it should include the veriloga file (resistor.va, in this case) associated with it.
Thanks and regards
    Andrew Beckett over 9 years ago +1
    You can't use ~ in pathnames which are tick-included in VerilogA. The ~ representation of a home directory is a csh-thing, not a standard UNIX feature. What you can however do is just do: `include…
    `include "somepath"
    and then on the spectre command line add -I$HOME to include your home dir in the search path. Or if you're using ADE, you can use the Include Path on Setup->Simulation Files to reference your home dir.
    If you want to include a VerilogA module not as a view, you'd have to ensure that there is a stopping view for that block (e.g. copy the symbol view to spectre, or mark it as a stop point in the hierarchy editor) and then define the CDF for the block so that it knows the name of the module and the terminal order (this is in the spectre simulation information). There are countless forum posts (and a blog from Tawna) telling  you how to do this. To include the actual Verilog-A code in the simulation, you'd need to add a model file (myVerilogA.scs, say) in Setup->Model Libraries which has the entry:
    ahdl_include "/path/to/resistor.va"
