  2. Mixed-Signal Design
  3. Connecting SPICE ports inside a SystemVerilog-only test...
  • Subscribers 64
  • Views 15095
Connecting SPICE ports inside a SystemVerilog-only testbench
Pacher Luca
Pacher Luca over 9 years ago
Dear all,
I'm trying to setup a mixed-signal simulation using SystemVerilog RNM and a transistor-level Spectre netlist for an analog block. I know that Verilog-AMS wreal nets can directly drive SPICE ports. Indeed, I want to use SystemVerilog-only constructs in my testbench, without the usage of Verilog-AMS constructs. However a direct connection between a real number and a SPICE port in not allowed since real is a discrete quantity. Does SystemVerilog allow to do this?
