  2. Mixed-Signal Design
  3. LSF batch jobs are killed on closing ADEXL window
  • Replies 7
  • Subscribers 64
  • Views 20118
Casp
Casp over 9 years ago
I am using IC6.1.6 and launching LSF jobs from ADEXL. I am using LBS --> batchq.
I am facing a problem that when I close ADEXL window then it cancel my jobs as well. I read on this forum that it should not be the case.
Can you please help me in finding why it kills the running jobs?
Kamran
    Kamran,
    Put these in your .cdsinit file:
    envSetVal("adexl.distribute" "continueICRPRunOnAbruptGUIExit" 'boolean t)
    envSetVal("adexl.gui" "continueJobsOnExitQuery" 'cyclic "Ask")
    The first is not the default value; the second is the default, but just in case it's been overridden somewhere, you might want to set it.
    If that doesn't work (you'd need to restart virtuoso - that's the simplest anyway), then contact customer support.
  • Casp
    Thanks Andrew!
    I am setting these variables in my .cdsinit.custom but seems like it is not working.
    I will contact customer support.
    Was talking about a similar issue today with a colleague, who reminded me that this only gets triggered when you exit virtuoso, not exit the ADE XL window...
  • Casp
    I am assuming that ADEXL also uses 'bsub' command to submit jobs in the background. If it is true then it should not be killed even if we close virtuoso.
    My previous reply might have been slightly ambiguous. Regardless of how the simulation jobs (the "ICRP") get launched (either local, remote or via a queueing system like LSF), the default behaviour is for the simulations to end when you exit virtuoso or exit ADE. This is because there is a communication channel between virtuoso and these remote processes, and one end would no longer be available. It has to do something special to deal with that channel no longer being there.
    That's what the envSetVal is for - it tells it to use a different strategy. This means that if virtuoso exits - either abnormally (i.e. a crash) or manually - then the background jobs continue (well, for a manual exit, you get a popup asking you whether you want the simulations to continue). That doesn't happen if you close the ADE XL window though - the assumption then is that because you've chosen to exit the ADE XL window, you are stopping using the tool.
    The reason why it works for exiting virtuoso is to deal with the situation where there is planned maintenance for the machine where you've launched virtuoso, and you are being asked to log out - but don't want the sims which have been submitted on the farm to die.
  • Casp
    Thanks Andrew for your detailed reply.
    If I understood correctly that there is no way we can recover the jobs if virtuoso crashes.
    Kamran
    Kamran,
    No, that's not what I said. If you use this env var (set to t), then the jobs will continue if the parent virtuoso crashes. You can then look at the results later when they've finished as usual.
