  2. Mixed-Signal Design
  3. Modulo operation in a decimal-to-binary converter
  • Subscribers 64
  • Views 23447
mixic
mixic over 9 years ago
I'd like to create a simulation device which converts an integer that is passed through as a parameter "_N" into a 8-bit bus. The plan is to use a vdc battery, and bit 0 is fairly simple (pPar("_N")%2).
For bit 1 I tried ((pPar("_N")-(pPar("_N")%2))%2), but it caused a fatal error
Unexpected character `%' in netlist.
Unexpected integer "2". Expected close parenthesis
By changing the formula to (pPar("_N")-(pPar("_N")%2)), the simulation turned out OK.
So why is the second modulo operation not accepted?
Thanks in advance!
    Percent (%) is not a valid AEL (Analog Expression Language) nor spectre operator (see the AEL documentation and "spectre -h expressions").
    Instead, I'd suggest you use pPar("_N")&1 or if you want to detect a different bit something like use (pPar("_N")&4)>>2 (this will detect nnnn1nn).
  • mixic
    Thanks Andrew. I just found fmod() would do the job for me.
