  2. Mixed-Signal Design
  3. Constraining inputs for digital block in analog-on-top ...
  • Subscribers 64
  • Views 14934
Constraining inputs for digital block in analog-on-top design
JCPR
JCPR over 9 years ago
I'm having some issues finding the right way to constrain some inputs coming from the analog section of our design.  What needs to be done is to sample a signal that can  change right after the clock edge (about ~10 ps), up to ~400 ps before the next clock edge. The clock period is 3.2ns. I would like the tool to add some bufffering, but not too much so that both setup and hold are respected. I've read the documentation of set_input_delay but I still find it a bit confusing, specially the use of the -min and -max option. I have tried the following two approaches:
set_input_delay  2.8   [get_ports {align_flag}] -clock clk
and
set_input_delay  -max  2.8    [get_ports {align_flag}] -clock clk
set_input_delay  -min .01  [get_ports {align_flag}] -clock clk -add_delay
I seem to be able to close timing with both according to my generated reports approaches, but when doing an SDF back-annotated simulation I still get  setup/hold issues sometimes, which tells me that what I am trying to ask the tool to do is not in line with my constraints. Should I take into account other factors when constraining my input ? (e.g. the insertion delay of my clock is ~150ps).
JC
