  2. Mixed-Signal Design
  3. Extracted View Netlisting Issue
  • Subscribers 64
  • Views 14598
MMueller
MMueller over 9 years ago
Hi all,
i have got an issue with the netlisting of my mixed signal design (using the UNL Flow):
I am running a "text on top" design from ADE Assembler with a config view - toplevel being a verilog view and an instance being a schematic view.
This worked fine until i tried to exchange the schematic view with an av_extracted view (created with PVS/ QRC).
The netlist with the schematic looked like this:
Module:
module SCHEMATIC_MODULE_NAME (BUS_NAME_A);
output [3:0] BUS_NAME_A;
endmodule
Instantiation:
wire [3:0] bus_wire;
SCHEMATIC_MODULE_NAME INSTANCE_NAME ( .BUSNAME_A(bus_wire));
which worked fine.
Now, the extraction view is netlisted as:
module SCHEMATIC_MODULE_NAME  (\BUSNAME_A(3) , \BUSNAME_A(2) , \BUSNAME_A(1) , \BUSNAME_A(0));
output \BUSNAME_A(3), \BUSNAME_A(2), \BUSNAME_A(1), BUSNAME_A(0);
endmodule
Which gives an error during elaboration....
I found that i can add a callProc.il to the QRC run in order to get [ ] brackets instead of parathesis (), but still the bus is split in this way, which means the simulation does not work.
Is there a way to get the extracted_view netlisted "the right way"?
Best regards,
Markus
