  2. Mixed-Signal Design
  3. Finding the magnitude of a plot at a particular time.
  • Subscribers 64
  • Views 16072
Charanraj Mohan
Charanraj Mohan over 9 years ago
I am aware of cross function where the threshold (in y-axis) is set and the corresponding x-axis value is obtained. Now I want to do the reverse. I have a plot that changes to many magnitudes. I want to see the magnitude (y-axis value) at a particular x-axis value. Note that the x-axis can be a V or magnitude (in simple DC sweep) or time (in a transient simulation). In any analysis plot, I just need the magnitude in y-axis for the particular x-axis. Is this possible for using function in the calculator ??
thanks in advance :-)
    You need to use the value() function.
  • Charanraj Mohan
    thanks Andrew :-)
